How Can I Obtain an Attribute's Prompt Message
Hello:
I am just playing around with LISP trying to build a little program for myself and I have run into a problem, I can get to the value and tag of a selected attribute using
[code]
(setq entity (nentsel "\nSELECT AN ATTRIBUTE TO EDIT: ")) ;Select an attribute - no bad selection handling shown.
(setq SelectedAtt (cdr (assoc 2 (entget (car entity))))) ;Get the ID of the selected attribute
(setq Object (vlax-ename->vla-object (car entity))) ;Get the object reference for my selected entity
(setq AttValue (vla-get-textstring Object)) ;Grab the value of the selected attribute [/code]
So, the one thing I am missing is how to get the prompt for the attribute that the user selected (or hopefully selected as my code won't work if they don't select one).
Any ideas?
You have to dig a little deeper for the prompt string. It is a property of the corresponding attribute definition. It is one of the few thing that an attribute reference actually references.0
If you are trying to create a Lisp utility to edit a single attribute you should consider two things:
1.
There are mtext attributes which can contain special formatting. You cannot display this properly in a DCL dialog.
2.
If you double-clicks on an attribute the BC Attribute Editor will open with the value of that attribute preselected. So if you want to change a single attribute there is no need to scroll and search. Just type the new value and press OK.0 -
Hi Roy:Thanks for the tip, I am still struggling but I am hoping to make some progress later today...Yup, I am building a light weight attribute editor - sometimes I find the supplied dialog cumbersome, mainly that the enter button jumps to the next attribute instead of just accepting the changes. I did run into the formatting issue this am when attempting to edit an attribute who's value was 3"=1'-0", it will take some interesting programming to write something to parse through the string and escape the characters before putting them into a dialog...0
I did a bit more digging this am and realized that ENTNEXT is what I need to get to the ATTDEF, but the next entity is a (0 . "SEQEND") not an (0 . "ATTDEF") as expected.[code](setq entity (nentsel "\nSELECT AN ATTRIBUTE TO EDIT: "))[/code]Returns: (setq entity (nentsel "\nSELECT AN ATTRIBUTE TO EDIT: "))[code](entget (car entity))[/code]Returns: ((-1 . ) (0 . "ATTRIB") (5 . "3E2FB") (330 . ) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (6 . "ByBlock") (100 . "AcDbText") (10 11.1683605145269 6.6679508020378 0.0) (40 . 0.09375) (1 . "-") (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . "PGSNotes") (71 . 0) (72 . 1) (11 11.2085390859554 6.7148258020378 0.0) (210 0.0 0.0 1.0) (100 . "AcDbAttribute") (2 . "ID") (70 . 0) (73 . 0) (74 . 2) (280 . 0))
Returns: ((-1 . ) (0 . "SEQEND") (5 . "3E2FC") (330 . ) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "TEXT") (-2 . ))
Should this last line of code not return an item that is (0 . "ATTDEF")?
The block that I am playing with is a simple rectangle with one attribute in it.
Have to repost, made a mistake with the output from the first line of code.....[code](setq entity (nentsel "\nSELECT AN ATTRIBUTE TO EDIT: "))[/code]Returns: ( (11.2454763312328 6.716128962967 0.0))[code](entget (car entity))[/code]Returns: ((-1 . ) (0 . "ATTRIB") (5 . "3E2FB") (330 . ) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (6 . "ByBlock") (100 . "AcDbText") (10 11.1683605145269 6.6679508020378 0.0) (40 . 0.09375) (1 . "-") (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . "PGSNotes") (71 . 0) (72 . 1) (11 11.2085390859554 6.7148258020378 0.0) (210 0.0 0.0 1.0) (100 . "AcDbAttribute") (2 . "ID") (70 . 0) (73 . 0) (74 . 2) (280 . 0))
To get to the attribute definition you have to start digging in the block definition.
You can do this using 'Classic' Lisp but I would use Visual Lisp instead.
[code]; (PromptStringAttRef (vlax-ename->vla-object (car (nentsel))))
(defun PromptStringAttRef (obj)
(cond
((= "AcDbAttributeDefinition" (vla-get-objectname obj))
(prompt "\nError: constant attribute ")
((= "AcDbAttribute" (vla-get-objectname obj))
(PromptStringBlockDef (vla-get-name (_Sys_ObjectOwner obj)) (vla-get-tagstring obj))
; (PromptString "TitleBlock_Small" "ClientAddress")
(defun PromptStringBlockDef (name tag)
(setq tag (strcase tag))
(if (tblobjname "block" name)
(vl-some
'(lambda (obj)
(if
(and
(= tag (strcase (vla-get-tagstring obj)))
(vla-get-promptstring obj)
(vle-collection->list
(vla-item
(vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
name
(defun _Sys_ObjectOwner (obj)
(vla-objectidtoobject (vla-get-database obj) (vla-get-ownerid obj))
)[/code]0 -
For comparison the 'Classic' approach.
[code]; (Classic_PromptStringAttRef (car (nentsel)))
(defun Classic_PromptStringAttRef (enme / elst)
(cond
((= "ATTRIB" (cdr (assoc 0 (setq elst (entget enme)))))
(Classic_PromptStringBlockDef
(cdr (assoc 2 (entget (cdr (assoc 330 elst))))) ; Block name from the insert.
(cdr (assoc 2 elst)) ; Tag from the attribute.
((= "ATTDEF" (cdr (assoc 0 (entget enme))))
; (Classic_PromptStringBlockDef "TitleBlock_Small" "ClientAddress")
(defun Classic_PromptStringBlockDef (name tag / enme elst ret)
(if (setq enme (tblobjname "block" name))
(while
(and
enme ; Will be set to nil if the attribute is found.
(setq enme (entnext enme))
(/= "ENDBLK" (cdr (assoc 0 (setq elst (entget enme)))))
(if
(and
(= "ATTDEF" (cdr (assoc 0 elst)))
(= tag (strcase (cdr (assoc 2 elst))))
(setq
ret (cdr (assoc 3 elst))
enme nil
ret
)[/code]0 -
Interesting, thank you for the tip, it looks like I cannot obtain the prompt directly from the attrib item, instead I need to grab the details of the parent block and go down from there. I appreciate the help!0
