Is there event for BRX of selecting object?
please see AcEdInputContextReactor... should be what you need ?
many greetings !0 -
Thanks!!!
Can you write simple example ?0 -
I do not have such example code at hand ... but simply check the web, very likely you can find a number of sample cases ...
many greetings !0 -
I experimented with AsdkInputContextReactor.
Called only beginQuiescentState(), endQuiescentState()
sometimes beginDragSequence(), endDragSequence()
not others.
I thinked, that when I will select object then will be called beginEntsel() then endEntsel().
but don't happened.
Why? Who was having same problems?0 -
How do you (your users) select the entity ? By entsel() function, or by clicking onto the entity ?
there is also reactor event for "pickfirst selectionset" modified by AcEditorReactor::pickfirstModified() - then your code can retrieve the pickfirst selectionset, to get all the entities actually selected.
I hope this helps ?P.S: beginEntsel() acts on acedEntSel() only0 -
Thanks for help.
I tried to use AcEditorReactor::pickfirstModified();
I Created my class.
Then i added
ArxDbgEditorReactor::rxInit();
acrxBuildClassHierarchy();
into
virtual AcRx::AppRetCode On_kInitAppMsg(void* pAppData){}
as was showed in example.
But when i load arx Autovad crashed.
How do i must use ArxDbgEditorReactor ?0 -
Hi, Oleg,
it crashes in AutoCAD ?
It seems best, to send a support request, with your project ... but of course, we primarily care for BricsCAD, not for AutoCAD problems;
so does it work or crash in BricsCAD as well ?
Btw., ARX also has tons of examples, with EditorReactors - try to compile their samples, to run in AutoCAD ...
you can then compare the Autodesk sample EditorReactor with your implementations.0 -
Sorry
Ofcouse i mean BricsCAD and BRX.
I inserted copy from my message for other forums )))0
