Black square when using gradient
Hello everyone,
I have a problem for several weeks now.
When I use a gradient to color a 2D area, I print it out and see that it has a black square around this area and this appear only by printing. When I use instead hatch function with solid model, it is ok, but in this way I can not use 2 colors. For better understanding, I have send a file attached.
Please help, I give up, I can't find this by my own...
  • We recently experienced a similar problem upon replacing the printing device, as it turned out there was a flaw in the device's drivers, the manufacturer, Ricoh, played around with the driver until it started working OK in our company.  You might want to test in different printers to see if the issue is printer dependent
    Jose
  • Thanks for answer.
    I have tryed this also at the beginning, but unfortunately it make the same for all printers: we also have a Cannon C2225. It does the same also when printing to .pdf. It's frustrating !
  • If you file a support request and attach a sample drawing our support analysts will be glad to help you out.
    Kind regards,
