Problem with P4M900
Hello.
I'm having the same problem that this guy, but on windows. I have the same VIA chipset it has (P4M900). The program crashes on startup, and I think that is an incompatibility problem with the onboard VGA. Because when I uninstall the VIA video driver and use the standard windows driver, the program works.
I installed BricsCAD trial to evaluate. It's been five days and even agorna could not use.
Thank you!!! Sorry for bad english, or any other inconvenience
Is there anything I can do?
