he workstation on which Bricscad will be installed will neither require internet for one-time activa
The workstation on which Bricscad will be installed will neither require internet for one-time activation nor for subsequent usage.Kindly confirm the same.Is there any offline procedure for installation of Bricscad.
You can perform a manual activation, which is covered in BricsCAD help
The machine you use for manual activation will require an internet connection. Once activated there is no requirement for BricsCAD to have ongoing internet access.
Regards, Jason Bourhill CAD Concepts0
