Strange Warning when open dwg - Unsupported AutoCAD Version 20.0 BRICSCAD
I only have this issue on Laptop. PC doesn't mention warning.
Both Win 7 Pro 64 bit.
Same file used to install version 16
When an existing dwg is opened in any way it gives a warning.
Warning: Unsupported AutoCAD Version 20.0 BRICSCAD
I have no idea what it means and haven't heard of a Ver 20.
I can't find anything via Google either.
Any comments appreciated thanks.
Version 16.1.02 (x64) revision 40514
  • Hi Richard,
    That message is coming from our GeoTools / CADPower add-on and means that you are using an older version of our tools which is obviously not recognized by BricsCAD V16.
    You will need to use the latest version V16.10 of our products to be compatible with BricsCAD V16.
    Reach out to me by email (rakesh.rao@4d-technologies.com) and I will help fix this.
    Best Regards
    Rakesh Rao
    Smarter .dwg CAD
  • Thanks Rakesh
    Email sent
    regards
    Richard
