All lines, arcs, text etc. slightly blurred in V16
I have just upgraded to V16 and now all my lines, text etc. are all blurry.
I have a Black background in Model Space and my Layouts are White and I am getting the same effect in both places.
Is there a new setting where I can change this to how it was in V15 or am I stuck with it?
I haven't changed any hardware, only upgraded Bricscad.
Obviously I can't post a screen shot as it would be meaningless.
Thanks in advance for anyone's help.
David
David
I think you are referring to ANTIALIASSCREEN.0
Thanks for the tip Roy,
I have had a look in settings and can't seem to work out which one of the AntiAlias settings I am supposed to change!
I have however found a way to demonstrate what is happening on screen.
When I used to hover over text in V15, the whole word would highlight in a solid colour, now it shows up with a sort of crosshatch pattern.
I have attached a .png to illustrate between the two versions.
Hopefully this may help someone figure out what is happening.
Thanks Again,
You can try to change HIGHLIGHTEFFECT. But I don't think you can change the crosshatch pattern when a TTF text (or any other entity displayed with a solid fill) is highlighted. I don't see the effect for line work if LWDISPAY is OFF.0
Have you tried setting AntiAliasScreen to 1?0
@Hans,
Thanks very much, that seems to have improved things a lot!
The crosshatch effect is still there on text and text is a little fuzzy when zoomed out, but the lines, arcs etc. are much sharper thank you.
I must admit, I thought I had altered this already, but I must have forgotten to press enter and it didn't take!
Thanks to Roy as well, we got there in the end.
All the best,
David0 -
Have you tried setting AntiAliasScreen to 1?V16-64bit:I had this problem solved in V16-32bit by setting Screen Antialiasing to "0"But in V16-64bit this does not seem to make any difference.Is there any other button to be clicked?0
Have you tried using the _REGEN command after changing AntiAliasScreen?0
I have restarted my PC - and it did not change anything.I am using a german version, so maybe there a misunderstanding from my side:the german command name is:Titel:"Anzeigen"Command:"Anti-Aliasing Stärke für die Ansicht"I believed this is the "AntiAliasScreen" setting???0
To avoid confusion try entering '_AntiAliasScreen' in the Command Bar.0
I have tried with "_antialiasscreen" - it is the same system variable.I have tried a different drawing now - and the blurry text is gone.It seems to occur only in ONE special schematic drawing - the others are OK now.
I have no idea what could be the reason for this - as in every drawing I have used ARIAL as text style - with i.e. ISOCP there was no blurriness.Must be a problem with the TTF-Fonts ???But:I want to give a praise to BRICSCAD V16-64bit:- It now has a lofting command for 3D-Modelling! And it works!!!!
- Switching from 2D-wiremesh to realistic view now needs about 5seconds (it was about 5times as long in V15-32bit)
Generally I am very happy with the upgrade.0
