wxWidgets & BRICSCAD do not work together. wxDialog::ShowModal() or wxMessageBox() do crash of Bric
wxWidgets & BRICSCAD do not work together.  wxDialog::ShowModal() or wxMessageBox() do crash of BricsCad.
"An unhandled exception at 0x0000000000000000 in bricscad.exe: 0xC0000005: Access violation while performing at 0x0000000000000000."
  • Hi Oleg,
    With some effort you can use WxWidgets from your code running in BricsCAD, but you have to compile and link against the same version and build settings of WxWidgets that is used by BricsCAD.
  • Hi.
    How can I see version wxWidgets of BricsCad?
    BricsCad  = V 15.3.05 (x64)   39062
  • Hi Oleg,
    Thanks for your help.
  • Hi Oleg,
    I installed wxWidges  Previous Stable Release: 2.8.12.
    When in BRX call
        HWND hWnd = acedGetAcadFrame()->m_hWnd;
        wxWindow * win = new wxWindow();
        win->SetHWND((WXHWND)hWnd);
         wxMessageBox( wxT("Quit program?"), wxT("Confirm"), wxYES_NO | wxCANCEL, win);
    BricsCad crash.
  • Also, I think BricsCad use 3.0.2 version of wxWidgets. Because sample in BRXSDK compiled with only version 3.0.2. With previous version of wxwidgets can not compile.
  • Yes, we use a v3 version, indeed ... likely v 3.02 ...
    there is a WXWIDGETS macro (#define ...) which instructs WX build to *not* include a CWinApp instance, as it is usually done for regular DLLs;
    instead, that extra CWinApp instance must be suppressed by that macro (similar to an extension DLL) - it is likely that extra CWinApp which causes
    the crash ...
    the crash ...
    Can you tell me what macro? I can not find similar  macro in Documentation of wxwidgets.
    CWinApp not mentioned in documentation of wxwidgets.
    the crash ...
    I use sample with wxWidgets from  BRXSDK.
    I compiled WX with keys  BUILD=release UNICODE=1 SHARED=1 TARGET_CPU=X64.
    In file StdAfx.h there are strings
    MFC includes
    OPTIONAL: remove these lines if your application does not use MFC
    #include
    #include
    #include
    If comment its then BRX do not compiled. Because some  function BRXSDK use MFC functions.
    Example
        //CWnd *pWnd = AcUiMainWindow();
        //HWND hWnd = pWnd->GetSafeHwnd();
    and other...
    When BRX call
    bricscad crash.
    When BRX call
                wxWindow* mainWindow =  wxTheApp->GetTopWindow();
    bricscad crash.
    Is there manual or description step-by-step how to use wxWidgets with BricsCad?
    Help me please.  My head does not understand what i can do yet.
  • Dear Oleg,
    first of all, no need to disable MFC linkage ... to prevent BRX compiler errors.
    The crash is very likely caised by instantiated CWinApp from WX modules - I will keep you updated about that *magic* WX preprocessor symbol, to disable CWinApp instance ....
    then, such simple WX message boxes should work.
    more to come & many greetings !
  • Dear Oleg,
    you will need to use
    IMPLEMENT_APP_NO_MAIN
    as
    wxIMPLEMENT_APP_NO_MAIN(MyApp);
    or better
    to exclude WX's message loop / CWinApp instance ... as Balint Pete told us, you are already informed, and the crashes are gone ...
    many greetings !
  • Dear Oleg,
    as
    or better
    many greetings !
    Thank you for help   ))))
  • Thank you.
    It is good info
  • Hi Daniel.
    It works ok.
    But it does not work if i try put wxWindow to palette.
    When i click on button, that puted on wxWindow, i get exaption
    wxWidgets Debug Alert
    ..\..\src\msw\button.cpp(272): assert "tlw" failed in GetTLWParentIfNotBeingDeleted(): logic error in GetTLWParentIfNotBeingDeleted()
    Call stack:
    [00] wxButton::MSWWindowProc                     d:\wxwidgets_3.0.2\src\msw\button.cpp:431
    [01] wxWndProc                                   d:\wxwidgets_3.0.2\src\msw\window.cpp:2716
    [02] DispatchMessageW
    [03] GetSysColorBrush
    [04] GetSysColorBrush
    [05] KiUserCallbackDispatcher
    [06] SetFocus
    [07] ImageList_SetOverlayImage
    [08] ImageList_SetOverlayImage
    [09] DispatchMessageW
    [10] CallWindowProcW
    [11] wxWindow::MSWDefWindowProc                  d:\wxwidgets_3.0.2\src\msw\window.cpp:2271
    [12] wxWindow::MSWWindowProc                     d:\wxwidgets_3.0.2\src\msw\window.cpp:3651
    [13] wxWndProc                                   d:\wxwidgets_3.0.2\src\msw\window.cpp:2716
    [14] DispatchMessageW
    [15] NotifyWinEvent
    [16] CharLowerW
    [17] 000000005C2FA9E0
    [18] 000000005C22BCCA
    [19] 000000005C2DFCFE
    [20] 000000005C2C51F7
    Do you want to stop the program?
    You can also choose [Cancel] to suppress further warnings.
