Use Export to export multiple layouts
I need to frequently make DWF's as a client output, but my driver Autocad DWF writer for 2d isn't working (almost). If I plot with this pc3, the file is created but with no layer information (and no option to turn it on or off).
I tryed the export option, and it work's just fine, with layers, but, I can´t export more than one layout at the time. The aim was to get a page setup equal to all layouts and then publish with that page setup.
Can you help me?
Thk's
What about output to pdf as an alternative? The PUBLISH command allows to create a multi-page pdf: one page for each layout. Use the 'Use Layers/don't include OFF layers' optio of the 'Layer information' setting to export the layers.
What about output to pdf as an alternative? The PUBLISH command allows to create a multi-page pdf: one page for each layout. Use the 'Use Layers/don't include OFF layers' optio of the 'Layer information' setting to export the layers.Thank you, but my client don't want PDF. I need to get dwf. Any ideas? I have a dwflayouts LISP that works, but I have a problem with images, they export all as black rectangles. Hope someone can help me.Regards,Luis
A pdf to dwf converter could be a solution?
Thank you. I'll give it a try. I prefer a direct method, but...
Howdy, Stranger!
