Sheet Sets - Modifying the Sheet List Table
Hi Guys,
I am currently working with Sheet Sets, and after i have created my set of drawings i would like to be able to insert a drawing index on my cover sheet.
Currently when i use the right click on my sheet set and 'Insert Sheet Table List', it does not give me any options of what information i would like on my table. Is there a way to modify that output so that i can use specific information from my sheet set?
Cheers,
Laura
Currently it doesn't look like there are any options with Sheet Table Lists. This is a new feature with V16, so hopefully they will expand to allow people to set up custom tables. Would also be useful if the table was updateable, rather than inserting each time.
Regards,Jason Bourhill
Thanks for your response Jason,Do you know if there is a way to insert fields and refer to different sheet set layouts?I find that when inserting a field i can only select the current sheet attributes i have set, but not other sheets.Regards,Laura0
