Tooltip on Mac
hi,
Are tooltips implemented on Mac ? In the settings dialog a hyperlink tooltip toggle is available, however the tooltip does not seem to show in BricsCAD on Mac...
I use tooltips for my app so i'm wondering if the BricsCAD Mac API does allow tooltips at all.
ty !
ty !
Hello Dirk,
I did not know that feature, I had to look it up.
Apparently hyperlink tooltips indeed does not work on Mac, please report in a support request.
I also tested the hyperlink menu, that does work properly.
I tested these steps:
- use HYPERLINK command to set a hyperlink on some object, including a description
- use HYPERLINK again to check whether the specified values are applied: OK
- enable ENABLEHYPERLINKTOOLTIP (disabled by default)
- hover over the object, the hyperlink description should appear: NOT OK
- enable ENABLEHYPERLINKMENU (enabled by default)
- select the object with hyperlink, right click (to avoid quad action on right click, keep right button down for context menu)
the context menu does contain hyperlink at the bottom: OK
Tijs0
