how to create report of coordinates of points
Hallo.
I need a report for geometry (x, y, z coordinates) for each point (insertion point of the block). I gave a serial number to each block. The result should be a table with the serial number of points / x coordinate, / y coordinate / z coordinate. I need this for indication of parcel boundaries.
Thanks.
Thanks.
Mateja
Not to step on any ones toes here, but that kind of function question may be better suited to "CAD TUTOR" or "the Swamp" those guys can figure out anything....0
Hello Mateja,
one of the new commands in V16 is DATAEXTRACTION.
What you describe is the kind of thing this command was made for.0 -
Mateja,
If you can't get the DATAEXTRACTION command to accomplish what you need or if you do not have V16 yet, I can probably help by writing a lisp routine to get the job done. I am in the process of developing an application for Land Surveyors and have some functions within my application that are similar to what you are needing. It might take some slight modification to get exactly what you need, but it can be done. You might need to attach or email me a sample dwg so I know exactly what you are wanting...
Thanks,
Kevin Simmons
