copybase on block editor
Hello,
I cannot do a copybase command when editing a block, or even a copy command. Why? That's a problem or a function that do not work in block editor?
Regards
Paulo Marques
Not block editor but XREF editor0
Paulo,
You can only copy items that are a part of the block being ref edited, non-faded out objects.0 -
Paulo,
You can however select objects then Cntrl ^C to copy to the clipboard prior to entering refedit, then while in the refedit mode perform a Cntrl ^V to paste from clipboard, to copy objects external to the referenced item within the referenced block.0 -
The ADD option of the Refedit command allows to copy entities to the block being edited. This option is available in the REFEDIT toolbar.0
