Anyone having a step by step instruction on how to work through IFC import/export on projects where some are using Revit and other BricsCAD V16? I guess the first step should be to make sure that the Revit users have installed the latest version of Revit IFC Exporter.
BIM is rather new in most ares of the Middle East. For many the announcement by Dubai Municipality, that "BIM has to be used on certain type of projects", have created great confusion. Autodesk Dealers are using this confusion to point out that Revit = BIM, and sell Revit licenses and training the best they can.
I have a large potential client working on a project where Revit/BIM is being used. They don't want to buy new Revit licenses and rather want to invest in BricSCAD V16 Platinum, but I don't have the necessary experience to guide them through the process of using IFC import/export in this information exchange process. They have tested IFC import to BricsCAD but claim that some information in the model is missing compared to in Revit. I guess that might be due to the way the information is exported from Revit and maybe also that the latest version of Revit IFC Exporter is not installed.
Any step by step instruction or guidance related to the IFC process will be very much appreciated.
Firstly the IFC format still seems to be somewhat of a notional ideal, the holy grail of a neutral file format that seamlessly transfers all information between the various BIM applications still has some way to go. i.e. You are likely to strike discrepancies when transferring in IFC format between differing BIM applications.
Around the world a number of government bodies are making declarations that BIM must be used on future projects. However other than a statement, they do not necessarily have any understanding of what they are actually asking for. To be clear BIM is not a file format. You could create a model with BricsCAD that fulfils all the requirement of BIM within the .dwg file format. The Bricsys BIM module is one example of this, and I'm sure that you could argue that many of BricsCAD's 3rd party applications also meet this requirement. i.e. You can meet the requirements of BIM without ever using the IFC format. Many CAD vendors are taking advantage of this confusion by stating you can get full BIM compatability providing you use there products. This is disingenuous, as many interpret it to mean full interoperability, which it most certainly is not.
In terms of specifics
Hi Per,
We are witnessing similar situation in India also, where many customers and statutory bodies sing the BIM (read Revit) mantra as the cure-all for all CAD ills. And of course, this is because of years of brain-washing to make them believe that it is either Revit-BIM or nothing else.
The truth is that a poorly designed BIM is a hundred times bigger disaster than well designed traditional CAD.
BIM is a fashion statement today. If you are not in it, you are considered an old hat. But BIM is for real and a game changer - only if you are willing to invest in understanding it. Even the most well-known BIM today is not without problems. I have heard this from the big companies themselves who admit the problems when it comes to sharing data exported with RVT files to other CAD systems. And that is precisely why someone is in a great overdrive to migrate everyone to using RVT BIM.
When someone like Dubai Municipality says "All data must be in BIM format", it is clearly a diktat doing the talking.
BricsCAD BIM may not yet be there to shake up the market leaders but is surely heading in the direction to offer an open-enough platform and a industry-standard neutral file format .dwg that you can always be confident of using with your perpetual license software.
As for IFC, agreed, it is the most neutral format but is more of a schema that offers data definition and content for a specific line of BIM workflow. I would not imagine it being possible to completely define an entire 3d building (with all its works) using IFC alone.
The question to ask Dubai Municipality is this. What is it they want in a BIM submission?
If you can explain how the BricsCAD .dwg BIM data contains materials and compositions, dynamic live sectioning, intelligent model regeneration and an option to export data in IFC when necessary, to me, that is as much BIM as any other BIM can be.
Best Regards
Rakesh Rao
Smarter .dwg CAD
This is an important topic, if you require any technical assistance please feel free to get in touch. Like Rakesh we are seeing a similar situation evolving in Australasia.
NATSPEC_BIM_Project_Inception_Guide_141120.pdfNBS-BIM-Object-Standard-v1_2_1114.pdfNATSPEC_BIM_Paper__Getting_started_with_BIM_140529.pdf
The Open BIM Alliance has been formed, partly in response to the mischief being put about that "BIM=Revit".
See http://www.brw.com.au/p/professions/seeking_standards_the_bim_project_cyNfoA9wvGRhXcjbDE029L
See http://oba.org.au/
Our company Sofoco has joined OBA and we hope that Bricsys will also join.
Revit has serious issues communicating with any non-Revit system. It is a poor tool for importing 3D solid geometry from AutoCAD DWG files, let alone other formats. So a Revit user has to do a lot of work to collaborate with other systems. As Rakesh says, this is probably the reason for the big push to get everybody using Revit. Even if the whole project team could buy Revit, one can't use Revit to design roads or carparks or furniture or to do steelwork shop detailing. You can do these things in BricsCAD.
See: www.cadtutor.net/forum/showthread.php?84183-Autocad-Solids-import-problem-with-Revit
Autodesk has NavisWorks as a tool for bringing different model formats together. But of course NavisWorks cannot be used to edit these files.
On the other hand, Revit can export ACIS solids to a DWG file which is easily opened and edited by BricsCAD. BricsCAD and DWG files can be used like Navisworks to view and often to edit other consultants data.
It is probably wise of Dubai not to define exactly what they want. I would interpret their direction as a push for the industry to move in this direction and to start learning what the issues are.
Damian
IFC is a open format which is allways readable and 'descipes' all object information. For this open and readable character it will loose speed and is will become slow. Importig will take some time. IFC should be considered like a 'moving box' to get stored information out of fileformat 'A', into to fileformat 'B' I like to think all CAD is CAD, either Revit, Tekla, AutoCAD, alls i CAD. To view IFC there are many tools. The beauty of IFC is that you do not have to depend on one developer. AutoCAD Civil3D can read eand export IFC as well. But this is programmed for use of road and meter models. It would be nice to have IFC import / export available as addon for AutoCAD and BricsCAD. What i miss in IFC is 'the drawing part', paperspace!
http://www.iai.fzk.de/www-extern/index.php?id=1138
Just my thought of IFC and BIM i like to share with you.
