BIM wall cut plane setting (Plan View)
Is it possible to set a cutting plane height for plan view so BIM model walls above windows/doors don't show up in plan view? Or, is there some other way to change the BIM model appearance in plan view so it doesn't show extra lines not needed for 2d construction plans, such as those noted above? Thanks.
