Line disappears in the drawing explorer.
Hello,
The bug concerns the Drawing Explorer. In the layers tab when I selects a line to change, for example the line type or thickness, the elevator scrolls up. Result, if I select the last line, it disappears.
I'm working with Linux Mint 17.2 Rafaela. Up to date.
I can confirm that there is a small glitch here - when I select some fields in the dialog, the table widget will indeed scroll down one line (ubuntu 14.04 / BricsCAD 16.1.07). But since turning the mouse wheel brings it back, this is not really a nuisance for me.0
