How to put transparency to an objekt in BricsCAD 16?
Dear Forum,
in AutoCAD its possible to put transparecy to an ocject with following LISP-Code:
(vla-put-entitytransparency vla-object value)
The function vla-put-entitytransparency ist not known in BricsCAD 16. How can I put transparency in a LISP-environment to an object?
Best regards.
Best regards.
[code]; Transparency:
; 0 ; Transparency ByLayer.
; (lsh 1 24) => 16777216 ; Transparency ByBlock.
; (lsh 2 24) => 33554432 ; Transparency 100%; Saturation 0%.
; (+ (lsh 2 24) 255) => 33554687 ; Transparency 0%; Saturation 100%.
; (_Sys_Transparency_Num_To_Perc 33554661) => 0.1
; (_Sys_Transparency_Num_To_Perc (cdr (assoc 440 (entget (car (entsel))))))
(defun _Sys_Transparency_Num_To_Perc (num)
(* 0.01 (fix (/ (- 33554687 num) 2.55)))
; (_Sys_Transparency_Perc_To_Num 0.1) => 33554661
(defun _Sys_Transparency_Perc_To_Num (perc)
(fix (- 33554687 (* perc 255)))
; (TransparencyPut (car (entsel)) "80")
; (TransparencyPut (car (entsel)) "ByLayer")
; (TransparencyPut (car (entsel)) "ByBlock")
(defun TransparencyPut (enme str)
(vle-entmod
440
enme
(cond
((= "BYLAYER" (strcase str))
((= "BYBLOCK" (strcase str))
16777216
(T
(_Sys_Transparency_Perc_To_Num (* 0.01 (atoi str)))
; (TransparencyGet (car (entsel)))
(defun TransparencyGet (enme / num)
(setq num (vle-entget 440 enme))
(cond
((not num)
"BYLAYER"
((zerop num)
"BYLAYER"
((= 16777216 num)
"BYBLOCK"
(T
(rtos (* 100 (_Sys_Transparency_Num_To_Perc num)) 2 0)
)[/code]0 -
Dear Albert,
next coming V16.2 will have (vla-get-entitytransparency) and (vla-put-entitytransparency) the same way as known from AutoLISP :-)
besides, as Roy mentioned, (entmod) or the BricsCAD-specific (vle-entmod) can be used with DXF 440 ...
many greetings !0 -
Dear Roy,
thank you for this tip!
Dear Torsten,
thank you for this information!
Many greetings,
Albert0 -
@Roy: Are "vle-entmod" and "vle-entget" lisp-functions, special made for BricsCAD?
I cannot find them it the developer reference: https://www.bricsys.com/bricscad/help/en_US/V16/DevRef/
Best regards, Albert0 -
Sorry, I found them :-)0 -
When using those "(vle-xxx)" functions, which do not exist in AutoCAD AutoLISP :
always load the "vle-extension.lsp" from your Lisp code, this file contains the emulations of "vle-xxx" functions, if those functions are not available as plain built-in Lisp functions.
Hence, the "vle-xxx" fucntions will be available in AutoCAD, ZWCAD etc. as well ...
vle-extension.lsp can be even loaded in BricsCAD also, does not harm ...
function definition is optional, if not yet present (simply see inside vle-extension.lsp).
More details in "Lisp Developer Support Package" in AppCatalaog
http://www.bricsys.com/applications/a/?lisp-developer-support-package-%28ldsp%29-a720-al1176
many greeitngs !0
