ViewSection: rotate section view relative to section line?
I am trying to create a vertical section using the ViewSection command. There seems to be a limitation in that the section view is always aligned with the section line. If the line has a 45 degree angle the section view will appear rotated as well. Is there a way to change this behavior? In the (Dutch) building industry vertical section are rarely displayed at a 45 degree angle.
Howdy, Stranger!
