Program Acroplot using wrong ctb with Bricscad
Hello,
I'm running Acroplot to batch multiple dwg's layouts. But something goes wrong with the plotstyle. Acroplot does not use the .ctb file saved in the dwg's layout (from Bricscad)
Does anyone know a solution for this problem? How does Acroplot find the plotstyles normally?
Regads, David
Regads, David
