BricsCAD V16: AutoLISP question. nentselp requires a string argument????
Why is BricsCAD telling me that nentselp is requiring a string argument? That's insane. The proper syntax for nentselp is:
(nentselp [optional PROMPT] [PT]). Originally, I wa getting an error because the point I selected was a 3D point instead of a 2D point. I fixed that, but now I still get this STRING error. This routine works perfectly in AutoCAD. I'm still working on it for BricsCAD and there are a couple of things I'm going to try, but I think this is a bug that needs to be fixed.
Bill DeShawn
It would be useful if you stated which version of BricsCAD you're using. Potential it's an issue that has been resolved in a more recent update? I don't see the problem with V16.2, Instead it fails at the command call to ATTEDIT. Looks like BricsCAD has a slightly different command line syntax to AutoCAD.
The Program is missing the RTD function, which I assume is radians to degrees.
You may also like to review your error handler. You can't call commands from here, Instead it is suggested to use command-s. Another approach would be to use vla-startundomark & vla-endundomark
Regards,Jason Bourhill
Bill DeShawn
This routine was using text as a model for the attribute, which was OK, but I wrote a new routine that just used the ATTEDIT command. Regardless, the nentselp function should not be requiring a string.
Bill
Regards,Jason BourhillThanks for the reply, Jason, but I'm not experiencing any problem with the error handler. And the routine works flawlessly in AutoCAD. The error I received was an error associated with the nentselp function. I'm going to upgrade later to get Visual Lisp, but not yet. Currently I'm just basic 2-D. Also, the version of BricsCAD is in the title of the topic. (V16).
Bill
You won't have any problems with the error handler if you're not striking errors :-). Try temporarily renaming your RTD function call to a non-existant function and re-run in AutoCAD. Doesn't seem to matter if you solely using BricsCAD.
With BricsCAD updates within a version number can be significant! There are a large number of new features and fixes included with 16.2 from previous updates. From the release notes it looks like your issue was fixed with V16.1.01
Dear All,
I just checked :
(setq res (nentselp))
works correctly in BricsCAD V12 or higher, just checked again ...
so the error is at a different place ...
Note :
the error call stack meantions "around", reporting the last-successfully evaluated expression, or the error expression itself ...
many greetings !0
