Mtext inconsistent behavior
Hi All
Please advice me.......i am new to Bricscad V.15
When I use Mtext.....
1. the bounding box width (grips editing) does not make any adjustment to my text
2. and the cursor is not place accordingly to the text.....
3. and the my preset settings etc indent, tab marker does not effect my text
is this normal.....anyone experience the same....please advice me to overcome the problem
Thank you
  • 1.
    Normally the text should (re)wrap when the mtext width is changed. But this does require 'normal' spaces in the text.
    2.
    I am not sure what you mean here.
    3.
    To change existing tabs for multiple lines of text you have to make sure that all the text involved is selected first.
