Change to Milimiters
When I change "Insertion unit" to milimeters the program still uses inches. (Settings>>Settings>>Drawing>>Drafting>>Drawing Units)
Thanks
Thanks
The INSUNITS setting is used for block scaling. Both the setting in the block file and in the 'main' file are used to determine a scale factor.
But maybe you also mean something else? Perhaps LUNITS? And looking at the MEASUREMENT variable may also be required.
Note that BricsCAD comes with mm templates and imperial templates. Starting with the right template can save you a lot of problems.0 -
In the options type 'template' and scroll down searching for Program options->Files->Templates
Here you have two important entries: "template" and "Default new sheet template"
Change this entries for "Default-metric.dwt" and be sure to enter all filepath" C:\blabla\blabla\Default-metric.dwt0
