BmBom convertion of volume?
Oops... 'convertion' should be 'conversion'.0
Hi guys, I guess it's solved by now. (blue)But the search lead me to here. So I'll politely "steal" your thread. (yellow highlight).
I've been struggling with units/BOM also.
Is there any obvious way to (suppress) control the behaviour of unit display in BOM?
In the case display exactly and only the precision requested, even if the return is simply 0.000 m³In the image highlighted with yellow is an example. If the "true" value goes beyond the chosen precision.
In this example 0.000 (3), it simply splash the entire value on the table.
In fact it happens for several options, not just volume.
Annoying to say the least.0
