Hidden Line Visual Style
What are the settings or commands for hidden lines to show in the hidden line style, in model space? I have been using Bricscad-Pro for only a few months. In an early project, hidden lines show as dashed, in both model space and in paper space. On a current project, hidden lines do not show, despite changes settings.
It is found in Drawing explorer | Visual Styles | Hidden | Edge Settings | Occluded Edges | Show and set that entry to Yes.0
Your instructions are correct, and greatly appreciated.0
Richard Webb's instruction, for settings in Drawing Explorer for hidden line presentation worked well with one DWG file (most appreciated). The same settings, tried repeatedly in a similar DWG file, do not result in visible hidden lines. Changing LTScale has no affect. Any other suggestions ?0
Try "msltscale" in the command prompt.
Set it to "on" or maybe "1". (In the german version it´s "Ein")
You might have to "regen" before you see the effect.
Sascha0
