Dynamic Blocks and Attributes with Fields
Hello,
I have successfully used Fields in Attributes for simple blocks, but when I add them to Dynamic blocks, the fields do not update after a regen or save.  I double checked the Field Update Mode and all of the update settings are checked.
Does anyone know if fields in attributes do work in dynamic blocks in BricsCAD v16.2 (they do work in AutoCAD)?
Kind Regards,
Lorna
