snap/ ortho- toggles not working during drafting
Most of the time F3 and F8 do not work in order to toggle snap and ortho while using a tool (polyline, move, copy).
They always work when not being in the middle of an operation.
I always have to switch these function on/ off in the menubar which makes my workflow stuttering.
Anyone knowing a fix? Is this the way it works in Bricscad?
Hi Clemens,I created Support Request about this issue - SR 66708 on On 17-12-2015 09:03 UTC.The last response from the Bricsys Team was on 05-01-2016 14:29 UTC:"Thank you for your detailed report.A task has been created to fix these issues. I will keep you informed ."Since than I have no additional information.Looks like in Version 16.2.04 it is sill not fixed.Maxim0
