draw a parable
Hi everybody,
I need to draw a parable. Somebody know how to do it with spline? It's possible?
I have changed the configuration for spline to cuadratic, but when I draw it, if I see his property, I always get grade 3 (cubic)
Help, please....
Thank you very much
  • One way to obtain a parabola (it indeed results in a spline) is using a cone and a section.
    * Draw a cone
    * Draw a slant section through the cone (one that does not result in a circle or triangle)
    * This results in a region, which you can explode in a spline and a line. The spline is a parabola (well, a clipped finite version of course).
    Of course you can directly manipulate a spline, but this way can be instructive.
    I think all that it takes is a spline with 3 control points, and the middle control point has to be on the perpendicular bisector of the other two control points.
    Regards
    Tijs
