Redefine Open command to RECOVER
We're chasing a couple of annoying bugs in BricsCAD that are avoided by auditing drawings. I'd like to redefine the OPEN command to perform a RECOVER. It seems easy enough but the recover command is not displaying the open dialog when executed as follows:
(defun c:open ( / ) (command "RECOVER"))
It works as expected when I type recover manually. Any ideas how I get the dialog to appear? I've already confirmed FILEDIA and CMDDIA are set to on.
[code](defun c:Open ()
(setvar 'cmdecho 0)
(command "_.recover" "~")
(while (/= 0 (logand (getvar 'cmdactive) 3))
(command pause)
(setvar 'cmdecho 1)
(princ)
)[/code]
Alternative:
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "_.recover ")
(princ)
)[/code]0 -
Perfect, thanks ...0
