When do you think you will develop an option to creat and edit a full dynamic blocks?
 in a 2d and allso in 3d?
  • Are you aware of the component mechanism that is already available?
  •  No, i'm new user, how i can make a block edit or dynamic block?
  • I think that AutoCAD only has 2D dynamic blocks. BricsCAD (partially) supports the use of these dynamic blocks. But you cannot create or modify dynamic blocks in BricsCAD. The component mechanism is an alternative technology that works for both 2D and 3D assemblies. For more info look in the Help or look for tutorials on Bricsys TV.
