Hi, I just tried on the latest Bricscad to resize an raster image using varia. Just after selecting the image the message "invalid index" and cannot resize it.
this should not happen, of course ... best to send us a SupportRequest (BugReport), with small sample dwg and image, as necessary, so that we should be able to investigate & fix the problem.
As a general hint : - try _audit / _recover once - run BricsCAD as admin once (see "run as admin" checkbox in desktop shortcut icon) - this helps to properly re-register COM interfaces
As a general hint :
many greetings !
