add ggrs87 / Greek Grid
 can you add this gis coordinate system ?? https://epsg.io/2100
PROJCS["GGRS87 / Greek Grid",
    GEOGCS["GGRS87",
        DATUM["Greek_Geodetic_Reference_System_1987",
            SPHEROID["GRS 1980",6378137,298.257222101,
                AUTHORITY["EPSG","7019"]],
            TOWGS84[-199.87,74.79,246.62,0,0,0,0],
            AUTHORITY["EPSG","6121"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4121"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",24],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AXIS["Easting",EAST],
    AXIS["Northing",NORTH],
    AUTHORITY["EPSG","2100"]]
thank you very much!!!
  • Hello,
    this is the user forum, for user-to-user communication.
    For requests to Bricsys development, please file a support request. Thanks!
  •  ok i downloaded bricscad trial to test the ggrs87 / Greek Grid  and it exists! but when i tried to use it in wms server and load from this http://gis.ktimanet.gr/wms/wmsopen/wmsserver.aspx the maps arent loaded!!
    you know geolocation command and mapconnect!! can you do something about that? thanks!!
