We came up with multiple sets of tool palettes, and set up macros on a ribbon panel to switch between those palette sets. Those work fine as the macros point to a static path that all users will have on their PC. I also would like to include a macro to point the path back to the default tool palettes, but it seems that the command does not recognize the Windows Environment variable and just creates a new tool palette folder in the Support directory. Does BricsCAD support these variables in macros, or am i formatting it incorrectly? Here are the examples.
This works perfectly to switch to the first set of tool palettes:
[code]c^c^_toolpalettepath;C:/BricsCADTools//ToolPalettes/ToolPalette1;[/code]
This doesn't seem to recognize the Windows Environment Variable:
[code]c^c^_toolpalettepath;%appdata%/Bricsys/BricsCAD/V16x64/en_US/Support/ToolPalettes;[/code]
[code]c^c^_toolpalettepath;(strcat (getenv "APPDATA") "\\Bricsys\\BricsCAD\\V16x64\\en_US\\Support\\ToolPalettes");[/code]
In this case you are probably better to use ROAMABLEROOTPREFIX instead
[code]c^c^_toolpalettepath;(strcat (getvar "ROAMABLEROOTPREFIX") "Support\\ToolPalettes");[/code]
You could also wrap the whole thing in a setvar
[code]c^c^(setvar "TOOLPALETTEPATH" (strcat (getvar "ROAMABLEROOTPREFIX") "Support\\ToolPalettes"));[/code]
