De- bulge for Polyline- editing
Is there a 'de- bulge' command for Polyline- segments?
As much as I love using the QUAD but this command is missing for me. Removing a segment simply does not do the trick, but something else.
regards,
Clemens
Look at the 'adjust Bulge' option of the PEDITEXT command (you just have to hit enter after selecting the bulge) - it can also be found in the QUAD...
Hi.Thanks for your response Knut.Unfortunately adjusting the bulge is something different than removing the bulge. That is what I really want to do.Simply create a line segment rather than an arc.I Should have been more specific about this.
Here is some Lisp code that should do the trick.
Note: Tested on BricsCAD for Windows. Let me know if it works on the Mac version.
[code](defun c:Debulge ( / doc enme elst)
(if
(and
(setq enme (car (entsel)))
(vl-position '(0 . "LWPOLYLINE") (setq elst (entget enme)))
(progn
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(if (= (logand (getvar 'undoctl) 8) 8)
(vla-endundomark doc)
(vla-startundomark doc)
(entmod
(mapcar
'(lambda (sub)
(if (= 42 (car sub))
'(42 . 0.0)
sub
elst
(princ)
)[/code] -
... Here is code for a 'per segment' action:
[code](defun c:DebulgeSegment ( / doc lst obj)
(if
(and
(setq lst (entsel))
(setq obj (vlax-ename->vla-object (car lst)))
(vl-position (vla-get-objectname obj) '("AcDb2dPolyline" "AcDbPolyline"))
(progn
(vla-setbulge
obj
(fix
(vlax-curve-getparamatpoint
obj
(vlax-curve-getclosestpointto
obj
(trans (osnap (cadr lst) "_nea") 1 0)
0.0
(princ)
)[/code] -
Hi Roy,Your LISP works on the MAC. Thanks.Exactly does what I want.Only thing is that I have to reload all LSP's every time I start BricsCad. Is there a way to Auto Load LISP's?I really would like Bricsys to include de de- bulge function into QUAD.
Some information on loading Lisp files is available on my website:
http://www.b-k-g.nl/loading-lisp-programs.html
Howdy, Stranger!
