MBS Tools
MBS tool box sorts out doors & windows on floor plans produced in MBS soft ware.
The tool box code is in VBA Has any one go MBS tools to work in Bricscad ???
Regards Julian B
VBA is only available for the 32bit version of BricsCAD. You also need to be using Pro or Platinum. If you've installed the 64bit version, then it won't work.
Regards,Jason Bourhill
... But even if your are running a 32 bit VBA-enabled version it is likely that the code will need to be modified. For example if the application is referenced as "AutoCAD.Application".0
