Basic Tolerances
in Other
I have several Autocad drawings that have dimensions with "basic dimensions" (the dimension number is surrounded by a rectangle). When opening these drawings with Bricscad, the basic dimensions are preserved. How can these basic dimensions be created directly into Bricscad?
Use a DIMGAP with a negative value.
Or in the Dimension Style panel of the Drawing Explorer:
Choose a dimension style > Text > Draw frame around text > On0 -
It works, thanks!0
