Objects highlight
Not sure what I have done, but objects are being selected as I hover over them. Driving me insane!
How do I turn this off please?
many thanks
Richad
Hi Richard,The easiest way to alter selection preview behaviour is to open the settings dialog box.Expand the Program options section,Expand the Selection section,Expand the Selection preview section,Expand the Selection preview display section,In that section you have two options that you can check or un-check, depending what you want to see, or not see.Alternatively, if you just want to turn off object highlighting off altogether type SELECTIONPREVIEW at the command line and set it to 0, see if that works.cheersandy0
Andy,Thanks, that did the trick!Richard0
Thanks, that did the trick!Nice one Richard :-), thanks for letting me know.andy0
