cannot load BRX
Hi, All,
was able to load BRX in the past, now i'm getting an error message:
Error loading "E:\CADWorx 2017-r20\Equipment\Support\CADWorxEquipment.brx": .
BRX is builded with vc 12 x64 and is trying to load into BCAD Platinum (Trial) v 16.1.02(x64) revision 40514
Did create autoload.rx with absolute path to BRX in it, did create short cut for my profile in BCAD, did add path to BRX in Program Options/Files/Support file seach path
What else is missing?
Thank you for any ideas,
Gennady
  • Bricscad V16 requires Visual Studio 2013 (platform toolset = v120)
  • Yes, it is msvc 2013 (vc 12).
    I was using BCAD v 16.1.02 and will test again with v 16.2.09, hope it will resolve the issue
  • did upgrade BCAD to 16.2, now it is loading fine
    SDK: v16_2_02. I was expecting 16 should be compatible with any BCAD 16
    Cheers!
  • Hi Gennady,
    Greeting from India, We are using Cadworx which works on top of AutoCAD. Recently we have downloaded the trial version of BricsCAD & just wanted to check if we can run Cadworx on BricsCAD (but could not do so). Searching the solution online, we came across your query & thought you must be using Cadworx on BricsCAD. If that is so, we would like to hear more from you.
    Thanks & Regards
    Chirag
