Flatshot lines not complete in v15.3.05
Hello all,
fla
i dont normally use briscad but i have been having trouble with a simple feature i was using in v14, which was flatshot.
It used to work perfectly on v14 but as we moved on to the new software v15 has had alot of issues with the flatshot feature where the lines projected arent complete or missing completely.
can someone tell me what is going on?
even if the settings are switched around within the flatshot pop up box the results are the same.
I did notice something similar in V15, but that was some time ago - the odd line was missing. Try using the VIEWBASE command, it will allow you to create the main view of your model, you can then project auxiliary views from that, along with creating sections and details. If you need the drawing to 2D manipulation run the VIEWEXPORT command (from the paperspace tab with your generated drawing views) to export the drawing as a block. The drawings created with VIEWBASE are linked to the model, if the model changes the views will update accordingly.0
