Bricscad have no replaceable syntax for the Justifytext ?? Please help me.
Hi there,
When I used AUTOCAD, this risp command is really usefull for me.
But in Bricscad, this risp can not running because "JUSTIFYTEXT" syntax is not supported. :(
I want to use this risp in Bricscad for more comfortable work same as in Autocad.
Does anyone know solution about this problem?? Please help me.
[code](defun c:t1(/ myerror os ss n ptx pty pyxy kw k en tx a)
  ;start --- Internal error handler -----------------------------
   (defun myerror(S)
   (if (/= s "Function cancelled")(princ (strcat "\nError:" s)))
   (setvar "osmode" os) (setvar "blipmode" bl)
   (setq *error* olderr)(princ) )
   (setq olderr *error* *error* myerror)
  ;end-----------------------------------------------------------
   (setq os (getvar "osmode"))
   (prompt "Justifying text")
   (setq ss (ssget '((0 . "text")))) (terpri)
   (setq n (sslength ss))
   (setq ptx (car (getpoint "\nSelect Base Point->")))(terpri)
   (setvar "osmode" 0)
   (setq a "Select Justifying point [Left(L)/Center(C)/Right(R)] : ")
   (initget "Left Center Right")
   (setq kw (getkword a))
   (if (= kw nil) (setq kw "Left"))
   (if (= kw "Left") (setq sn 10) (setq sn 11))
   (command "JUSTIFYTEXT" ss "" kw) (terpri)
   (setq k 0)
   (while (<= 1 n) </div>
      (setq en (ssname ss k))
      (setq ptxy (cdr (assoc 10 (entget en)))  )
      (setq pty (cadr ptxy))
      (setq pt2 (list ptx pty))
      (entmod (subst (cons sn pt2) (assoc sn (entget en))(entget en)))
      (setq n (- n 1))
      (setq k (+ k 1))
   (princ)
)[/code]
