Is possible define better "DPI/resolution" for Paper space?
I understand why detailed part drawing ie. pump, printed in 1:50 look like "smudge", it's because model is generated to virtual paper, like real and if are 10 lines with 0,5 mm weight between, it must look like "smudge".
But I mean, if is Viewport set to 1:50, it will be printed 1:50 on paper and also virtually I see and can zoom max. to 1:50, not behind (like 1:25 for better details).
If I print from this PDF, it's OK, but If I want view this PDF on monitor, I want see here more details, is this possible?
With detail like if I make scaled drawing frame in model and print from model.
Exactly I mean like this "hack" - but some direct set from BricsCAD:
- need print "hires" in 1:50
- make paper space
- make viewport, but not 1:50, but 1:5
- print it not 1:1 abut 1:10
- and this is what I need (but quite correct, beacsuse if I understand well PDF can't have "dynamic" lineweight according to scale, like it have model space)
I don't use line weights so I cannot make a suggestion.
Do you need to?
Many people use layer colours to associate pen thicknesses when printing, then everything appears thin on screen.
Some drafting standards do not allow line weights.
Ongoing saga about faded model space objects on PDFs.
