Iges import in V16 classic
We want to import IGES files in Bricscad Classic V15 and V16 (x64).
The well known plugin from Sycode is only for 32 bits.
Is there a way to import IGES without having to upgrade to the Platinum version?
We are running on Windows 7 pro 64 bits.
Johan
One possibility would be to use Freecad from
http://www.freecadweb.org/wiki/index.php?title=Download
Import IGES > Export DAE > Import DAE to BRICSCAD
or follow Instructions in http://www.freecadweb.org/wiki/index.php?title=FreeCAD_and_DXF_Import#How_to_install
to be able to Import IGES > Export DXF > Import(Open) DXF in BRICSCAD
...hope this help0 -
Johan,
You can try Bricsys Communicator: https://www.bricsys.com/nl_NL/communicator/
Bricsys Communicator needs BricsCAD Pro, not necessarily Platninum.0
