xerces error
in Other
Hello!
I have the following problem: Xerces error on the screen to open the program, how can I solve it?
You have attached and error
Please help me solve the problem!
Thank you!
This seems to indicate that your default.cui is missing and/or corrupted ...
simple trick :
copy the default.cui (or maybe all .cui files)
from /UserDataCache/Support/
to the user-folder as indicated in the error message ...
then all should be fine again ...
hope this helps & many greetings !0 -
ok thanks, I did it!0
