mechanical browser - create custom library
hello, i have been using bricscad for a while now & are using it to 2d drawings, i receive 3d drawings from clients
i want to use the mechanical folder & have my custom parts in laibrary so i can use on each new drawing
is there any training on this on BricsTV as i cant find it
regards
Darryn
  •  انڈے کے ساتھ چاول کی اچھی ہے، لیکن انڈے کے ساتھ روٹی بہتر ہے
    میں نے مدد کی ہے
  • Hi Darryn,
    I don't know any way to add to the mechanical library, but you can very easily build up your own set of tool palettes.  You can add your custom parts as blocks to tool palettes, then use these in creating new drawings.
    Please look up Tool  Palettes here:
    https://www.bricsys.com/bricscad/help/en_AU/CurVer/UsrGui/index.html
    Eg if you have an existing block in a drawing and browse to that block in the Drawing Explorer, you can right-click on the block and 'Add to current tool palette'.
    Damian Harkin
