Remove dmfix3d
hi, i am new to the CAD interface, and i'm still trying to get my feet wet in the CAD world. I found out that i can "fix" a 3d object by using dmfix3d, but i can't seem to figure out how to "unfix" the fixed object. Anybody knows the solution to this problem?
Open the Mechanical Browser and delete the appropriate 3D constraint. Note: You may have to drag the bottom edge of the top panel to see the full tree.0
that works perfectly! thanks for your help
