Always use crosshairs, V16
Jeff,I'm not sure if this is the same thing you're looking for, but the settings for crosshairs size exists under Settings/Program Options/Display...unfortunately, it doesn't work on the Mac version of BricsCAD (or at least not on mine, which is V161.08). I set mine to 100 but it doesn't change the size. I too would like the crosshairs to be full screen, if that's what you're referring to.0
William,
yes, crosshair size is there. I had set it to 100, and it does work on my Mac, but I was also trying to have the crosshairs on all of the time, not just when specific commands were activated. I don't how it happened, but now the crosshairs are always on despite not finding the "always use crosshairs" switch.0
