MTEXT cannot control font formating
Been trying to use v16 MTEXT on a Mac, but I cannot set the font size or format to anything but the default. My text styles are all set to zero height, so they should allow for variable text heights. I can change the text height in the Property Bar, but not within the MTEXT editor. When I do set the height in the Property Bar, that height then becomes the default in the editor. Am I missing a setting or something? Anyone else encounter this problem?
I can reproduce this problem, the character height combo box indeed does not work in the MText toolbar.
I noted this as an issue with urgent priority.
It is still useful to enter a support request, so we can notify you about the progress (you can mention internal issue number #7156).
Kind Regards
Tijs Vermeulen0
