VBA6 under windows 10
[code]Hello,
Fail to run a VBA macro in under Bricscad V4.0 operating system with Windows 10. The message is "To run Visual Basic, you have to install VBA6 Will". Strange because after upgrade from version 8 to 10 worked. I had a problem with OCX files after I installed Office but was resolved. I changed the way in Registry Editor - HKEY_LOCAL_MACHINE - Wow6432Node - Microsoft - VBA "Vbe6DIIPath" "REG_SZ" "C: \ Program Files (x86) \ Common Files \ Microsoft Shared \ VBA \ VBA6 \ VBE6.DLL".
Can someone help me?[/code]
