Copying text with \u+00b3
in 2D Drafting
Hello,
probably bug in program when copying multiline text field (_mtext) from one dwg to another.
Text contains \u+00b2 - "to square"
Anybody knows why?
Maybe the second drawing is using a different font for the style of that mtext entity?
Style is an entity property, but the DWG file defines what font is used for each style.
If the target file doesn't already have the style used in the mtext entity, then the entity brings the style in with it.
But if the target file does already have that style, then it uses its own definition of the style.0 -
Problem recurs when I reopen filetext style - does not matter0
Marcin, if you want help from the forum you should post two drawings (source and target). But most likely Anthony's diagnosis is correct.0
