Find and Replace for same title block on multiple layout tabs
I would like to be able to simply select all layout tabs and perform a find and replace to change the same title block attribute across all layout tabs. For example there is a date and job number attribute that will be the same on all layouts. The only way I have found to do this is to tediously go to each tab and edit these individually. Is there a way to do this?
Try the _FIND command.0
You should use attributes referring to fields in your title blocks. See attached document for more information.0
