In Object Arx [Model dialog change into Modelless dialog]
//Before run this below code, dialog become Model
SendMessage(WM_CLOSE_SYMDLG); //Call CloseACMDialog(WPARAM wParam, LPARAM lParam)
TCHAR pszInput[MAX_PATH];
CString strMsg=_T("Enter number");
int nRet =acedGetString(1,strMsg,pszInput);
if( nRet != RTNORM)
return;
CString strInput=pszInput;
SendMessage(WM_SHOW_SYMDLG); //Call OpenACMDialog(WPARAM wParam, LPARAM lParam)
LRESULT CRunModelDLG::CloseACMDialog(WPARAM wParam, LPARAM lParam)
PostMessage (WM_KEYDOWN,VK_ESCAPE,0);
EndModalLoop (RunModalLoop (MLF_SHOWONIDLE));
return TRUE;
LRESULT CRunModelDLG::OpenACMDialog(WPARAM wParam, LPARAM lParam)
ShowWindow(SW_SHOW);
RunModalLoop(MLF_SHOWONIDLE);
return TRUE;
//After run above code, dialog become Modelless
Problem in RunModalllop
How to maintain the dialog is Model?
With Regards,
N.Vijayaraghavan.
